LEMFO LEM5 smartwatch how do i enable background data for Pl
How do I enable background data for play store I know how to do it on a phone but cant even find data usage on this watch
download google gesture and write data usage and it will take you there, yes, it is annoying that it is'nt visible.
Sorry I am new to all this , can you give me more info. on this as I typed google gesture on the google site and ended up a whole heap of stuff
Thank you for your help I worked it out . but I still have a problem  with downloading G Mail app ,it seems to download and install , but all I get is the the mail box symbol and that is it I press on this but nothings happens as anyone had this problem with g mail on this watch
change you display to square and you'll have the access to continue. have you manage the data usage problem?
Yes I have fixed the data problem thanks to you but I cannot down watch faces , will that work if I change display to square for my problem with G Mail as I all I have is like a wallpaper with nothing to press it is just like a photo I have downloaded ,but I have not tried it yet will I have to download the gmail after I have changed it to square I did try changing to square once for something else but nothing seemed to happen
Hi again just tried that with square screen , the problem is it says it is downloaded and installed , but there is nothing to open all I get is a blank white screen with the gmail M symbol  and nothing else I press on the M symbol but nothing happens , it is like I have just downloaded this G mail symbol
it should work, i have it on my watch and it works fine but yes with square display you'll reach next...about watch faces, what do you need?
watch faces are not important at this stage I have just tried to download a couple just to see if it worked but none seemed to work,
I am just watching my watch and yeah I clicked on it now it has been stuck on getting my messages for about 15 minutes
Yeah you are right again and thanks very much but it is a lot of trouble this watch , so if I swapped back to round face now does that tell me I wont be able to check my mail or do I need to leave it in square screen , anyway you have been a great help and I do thank you very much
Mar 8, 2017 10:48:08 GMT 1 bandit said:
watch faces are not important at this stage I have just tried to download a couple just to see if it worked but none seemed to work, I am just watching my watch and yeah I clicked on it now it has been stuck on getting my messages for about 15 minutes
no, you can move from square to round in any time even when you are in the app itself. if you need help with watch faces how to set feel free to ask:)
