LEMFO LEM15 Battery change
Hello everyone,
Does anyone have any idea how difficult it is to change the battery in the watch, or is there a tutorial on how to do it?
And where I can buy a battery?
Thanks and best regards,
NOISE
There you have, men.
Directly from AliExpress.
Good job. I had a look, but I didn’t find it.
THANKS for the Link !!!
You’re welcome.
I have a Lemfo LEMP. On this watch, it’s not difficult at all to replace the battery. Only remove the four screws on back, and carefully remove the case and the battery flex attached to the top of the main board.
Be careful with the water seal (if you have one) around the main watch body.
