lemfo lem12 pro won’t turn on. Yesterday I connected to charging, I had 70% wanted to recharge to 100%. Sam turned off and no longer responds. I press the button to turn on and nothing, black screen
Mine did the same a week ago. On charge the watch gets very hot. Will not connect to PC, and even after disconnecting battery and reconnecting would not switch on or content to pc.
Do you remember what firmware you were using ?
last actualisation
Could you try to press and hold both buttons for about 1 minute, please?
what for, it does not work, I held both for 15 seconds and nothing, so a minute will also do nothing
Oh sorry. I didn’t mean to bother you with my help. I notice immediately that you have a very in-depth knowledge of these watches. So there is not the slightest need to waste a whole minute pointlessly…
if I’m wrong, correct me
I think you mistook me for someone else. I only put 1 post on my smartwatch topic here. I think that it’s a waste of time to hold both buttons, since normal 15 seconds will not do anything, then keeping the buttons for 1 minute will not do
I made this suggestion because there are some watches that require you to press both buttons for more than 45 seconds.
I am not suggesting that it is a panacea.
Even turned off, the device should turn on the display when it is connected to electricity, and it does nothing. No animation, batteries hot
You are wrong. But I’m not in the mood to publicly discuss this with you. PM me if you want.
ok, I’ll check it out, but it probably won’t help
I just said it’s worth a try…
I did what you asked and nothing. I held one button and both for more than 1 minute and it didn’t work, the smartwatch died and that’s it
I dont know if you realise you are doing it but your tone is " rude and negative " . When someone tries to help you this is not the way to respond .
Yes it was V06_20201102
I had a similar issue, shortly after I first booted the watch. I set up screen lock and a few minutes later I could not get out of screen lock any more. After entering the correct pattern just a black screen appeared and the screen got locked again. I was able to reboot the system but after booting the screen was black again.
The only way I could solve this issue was to flash the firmware with version V06 as described in the official Lem12 Pro thread.
Since then the watch works super smooth.
Hi there!
I’ve been looking around the forum for a day or two, and I have to say im really impressed with everything! I’ve always wanted a watch that runs proper android, but the trouble was actually finding one! Everytime I searched “Watch running Android” or some similair but much too vague search term, a bunch of wearOS watches came up. Well it must have been my lucky day because I came across Smartwatch Ticks, awesome channel really helped me figure out what the market for these watches is like. Anyway, i’m looking to get the lem 12 pro to use as a phone replacement (I dont use my phone too often so this is all I really need), but i’ve seen that some people are running into issues with charging and overheating? Is this isolated to the latest V6 firmware, or is it more widespread? Should I worry about it? How long is too long to leave it on charge? Thank you in advance for answering my questions!
Do not buy lemfo lem12 pro. It is defective, the battery overheats and burns the CPU. Low battery lasts max 1 day. Better check out TicWatch Pro 3 LTE or KOSPET prime2
