Hello Pablo. @pablo11
I bought Lemfo lem10 two months back. It is great watch, really liked it, Initally its IMEI was fake, it was used from some other mobile phone. I contacted on AliExpress several times and they suggested me to follow some method to root it and then run some commands. Also there were some links to your “fullandroidwatch’s” old website… i think something like androidroundwatchetc.
I tried many methods but never got succeeded.
Later, since I bought this watch its GPS never worked properly. it gave me location and then started jumping position to next streets and some times to next roads of almost 10s of KM difference… I started sharing my watch’s GPS position using Google maps to my iPhone … and a very few times I could see my iphone and my watch location is same . and that only when I am in home. or a few times out but other that that… my watch is always different in location and phone is different.
I had been testing this all using WIFI (hotspot of my iphone) and 3G and 4G.
I changed my SIM from a chinese Telecom company (Zong) to Telenor. ( Since you are connected with telecom devices you might know both networks. )
GPS only worked for a longer when I use my sim on 4G it started getting hot like IRON… and I can’t wear it for long time. I remove it make it 3G and leave it to cool down… and my battery drains only in hour or even less that that… even on 4G it shows position for a moment and when I start moving it’s position gets lost. it makes me to take un-necessary uturn and turn left or right or whatever it is getting position form.
I was also in touch with skype support, but my issue never got fixed. Today when I was talking with skype support, I said to share me the default firmware for Lemfo LEM10, and I also said that i’ve used v0.3 (from Lemfo.com) and v0.8 and 0.9(current installed version) from fullandrdoidwatch.org. the support guy over there Maria Zhoa suggested me to talk to you “Pablo11” because you are the found of this forum and lemfo’s technical personl. You can help me in this.
Now you tell me what should I do to get GPS work properly. Or any MK settings to enable GPS work great?..
Please see different screenshot to understand difference of location.
two images also showing the tracks of watch and iphone … i kept on both and watch only noticed 8 positions and drew a path connecting those points .
please consider this a humble request to suggest me fixing this
Thank you
