With Google+ is no longer available, please what is best site to download watch faces for LEMX?
Just ordinary ones, not ones that need a loader
Apr 5, 2019 12:36:34 GMT 2 yoyo5757 said:
With Google+ is no longer available, please what is best site to download watch faces for LEMX? Just ordinary ones, not ones that need a loader
On our new web you’ll find what you need:)
yoyo5757, the message at the top on the front page tells u where to go, but if you didn’t notice it I can tell you that the address is www.fullandroidwatch.com
Hi guys,
Question of the day : I installed “Yuka” from google play play.google.com/store/apps/details?id=io.yuka.android (And a couple of similar apps), but the camera doesnt seem to recognize barcodes.
Any info/confirmation/workaround on this?
Thanks,
Nicolas
Mar 23, 2019 9:32:06 GMT 2 denisj said:
I have exactly same problem But I use Huawey Mate 20 Pro.Have no sound on notification.
Have no notification about the calls.
Also when I receive notification I can only dismiss and I can’t read it.Thanks all
Denis
I have posted about this many times. Firstly, the watch is designed to notify you that there is a message on your phone. Not to read it or reply to it. Secondly, there is an update coming that will allow you to choose if you want the screen to light up when a notification arrives or not.
Ok... I undrstand if I can not read all notification, but only the title But why I have only vibrate and I have not notification sound ? ...sometime it's work also the notification sund... about one in 3 days :-(
Add also… can I answer using the LemfoX on my phone calls via BT ?
If yes… why I didn’s see the call arrive on the Lemfo X ?
I just want to return it back to Amazon, but I like too much the big screen that I can see with out glasses :-)
Is out there some watch with same big screen ?
Thanks all
Denis
Jan 27, 2019 9:49:32 GMT 2 pablo11 said:leafar
This is coming for the LEMX very soon
Notifications will light up the screen - or not. It will be a choice.
It works very wellPablo11 factory reset unroot the device and I got the latest firmware 20190306 and nothing about the picture I will for you to talk to Lemfo again if they are going to make this option feature available and can you ask too for the Max brightness or so, I did everything in order to get this feature and Lemfo let me down
Apr 10, 2019 7:00:14 GMT 2 denisj said:Mar 23, 2019 9:37:09 GMT 2 pablo11 said:
Ok... I undrstand if I can not read all notification, but only the title But why I have only vibrate and I have not notification sound ? ...sometime it's work also the notification sund... about one in 3 days :-(Add also… can I answer using the LemfoX on my phone calls via BT ?
If yes… why I didn’s see the call arrive on the Lemfo X ?I just want to return it back to Amazon, but I like too much the big screen that I can see with out glasses
Is out there some watch with same big screen ?Thanks all
Denis
Use Watch Droid is amazing! And work all good!
It would be cool to have the “always time” feature supported on our LEMX !!!
LEMfo LEM X is really amazing fablious smart watch but hte only missing part which is most important is (BT calls) what about LEMfo LEM X is there is firmware (BT calls enabled) work on it ?
No bt call on Android 7 watch…
the latest firmware update,the watch feel better with touch sensor display, the motion hands bright between 3 or 4 seconds and it connects right away using watchdroid.
Hi guys I am new on this forum and Regards to everyone!
Can somebody tell me why I have several bubbles under the screen glass on my brand new LEM X? I see it on some other lemX pictures as well!
There is a screensaver on the display. You can remove it.
Thank you for your answer. No the screen saver is off. It looks like the bubbles are between the screen and the glass.
If the screen saver is off and you have removed the screen protector ( which is normally the problem ) you must have a faulty screen ? Which is odd as other reported screen issues are not what you have described
When the watch is delivered to you, there are 2 foils on the display. The first (with a paper flag) is a protective film for the protective film. The bubbles are often under the 2nd film.
I have never seen bubbles in the display.
Guys you made me a happy man. You are RIGHT! I checked the watch again and find this 2.
protecteve film. Thank you very much for your help!
In the future I try to not bother you with this kind of questions, but please let me know do you suggest me to remove it? It seems to me rother sick anyway and I do not want to see this bubbles if not necessary!
I have never been called that for a while
Remove carefully yes . Slowly with fingernail
Edited…
