Well
i’m near 60.
To fill the next 20 Years comfortably i did my PPL(A) 5Years ago and live a little bit faster.
There are the expierience that the lemX has full network at 5000ft agl - where all full size handys and tablets are going down.
Well
i’m near 60.
Feb 8, 2019 14:02:05 GMT insedere said:
Welli’m near 60.
At 54 I live both faster and slower. Faster when I’m on my cyclo-cross bike, slower when kayaking. Lem X is a good companion.
I’ve read some of your post. You use Lem X with sim card like me. Why do you use online navigation? Offline navigation works great and quite long with Lem X. Altitude readings are surprisingly exact.
Feb 8, 2019 0:51:08 GMT capt jon said:Feb 7, 2019 20:23:09 GMT cranstonsnord said:
You have a very young looking face!!
Both of you make me feel old. I hit the 3/4 century mark this year.
Jan 24, 2019 3:49:50 GMT pablo11 said:
Hi mate,
I am fairly certain that you have not been able to get proper root on your LEMX.
My advice to you is to use the latest firmware. Patch the latest boot image with Magisk.
Before you flash the patched boot and recovery - copy the latest Magisk zip file to your watch storage. Make sure it is the flashable zip and not the Magisk apk.
Then flash just twrp and the patched boot image together.
Boot the watch normally and enable usb debugging.
Use ADB to reboot to recovery with this command - adb reboot recoveryOnce you get into twrp tick the box to allow modification to the system and then flash the full Magisk zip file.
Reboot the watch. DON’T wipe cache and dalvik before you reboot.
Install busybox to system/xbin - this is important and needs to be successful for root commands to function properly.
If it completes the busybox installation successfully you will have correct root access.
Feb 9, 2019 15:13:26 GMT mwireless38 said:
Jan 24, 2019 3:49:50 GMT pablo11 said:cranstonsnord
Hi mate,
How do o install busybox? Can I just install once I have magisk installed?
Feb 10, 2019 1:09:04 GMT pablo11 said:
Busybox is just needed to facilitate successful root commands within the Android system.
Feb 10, 2019 9:43:04 GMT joseph1234 said:Feb 10, 2019 1:09:04 GMT pablo11 said:
I was reading about busybox a lot trying to understand why I needed it. No success. Root explorer does need it but I found that EX Explorer can do without it. As much as I hate bloated ES I use it when messing with root files and uninstall it afterwords. So why do I need Busybox?
Feb 7, 2019 9:04:59 GMT joseph1234 said:
I'm in between you - age wise and I've learnt a lesson. Never too late. That's funny that over the computer everybody seems to be younger.Back to battery. I think that you don’t need so long samples like 10 hours to figure out what eats on your battery. This watch (at least mine) has
extremely well calibrated battery gauge. It’s very reliable. Normally I can predict battery drain within one hour. Once, when I tested some launcher battery gauge went totally nuts. Luckily it went back to normal after uninstall.I don’t know what apps you have installed there but you have an option to come back to bare bone stock firmware and start from there. I didn’t install latest version so I’m on December 17-th. One thing I learnt is to never install updates without reason. Anyway, if you make full TWRP backups it takes 5 minutes to come back to any firmware/setup without loosing your data.
I removed Macrodroid, and my battery is back to normal. Yesterday I took it off the charger at 6am, at 11:00 that evening, it was at 83%. I am not sure what was going on. I was only able to get the macro to work using either the floating button or a widget. The other options I could not figure out. I may reinstall Macrodroid later and try it again, or maybe see if Lemfo will actually unblock the brightness on the watch itself in a firmware update.
I think that reason for your battery drain was particular trigger you chose. With the hot spot on the screen you created permanent listening event which required CPU activity.
Try to use macrodroid shortcut as a trigger. The precise name of the trigger I use is “Shortcut Launcher”. I use two triggers like this (one for brighter, one for dimmer). They are shot through SwipePad.
Sometimes simplest things are hardest to find. I’m searching for simple dialer for Lem x. The stock one doesn’t display names in calls history neither lets me to add entries to contacts - long press doesn’t work. Pretty basic stuff.
I searched high and low, even used Yandex to avoid Google search tricks. Nothing. Finding free app without adds is next to impossible these days. There was one but it nagged me to sign to my Google/Facebook account for a change. I tried to transplant phone app form my previous watch to no avail - too many strange apk files and they don’t want to install themselves.
Not being able to customize so many things on Lem X is the weakest point of this watch - at least for me. Developers removed many important android settings and left one option that is of no interest to me: super easy clock face swap. How many times did I initiated it unintentionally by pressing the screen half second too long?
i have few question on lem x(iphone x)
how to have incoming notification SOUND on lem x that is connected to iphone x via bluetooth. i only get vibrates.
how to avoid repeated notification. i keep getting back the same notification every few minutes. is annoying.
how to have my lem x to be able to have bluetooth call & answer and reply whatsapp/message in the watch itself.
the above all is an issue for iphone user which many have mentioned. please do help out if anybody knows.
any solution that need to root device can be mentioned too. thanks.
Feb 11, 2019 15:00:27 GMT joseph1234 said:Feb 11, 2019 9:45:15 GMT cranstonsnord said:
I tried that (shortcut launcher), but no shortcut would ever appear in my launcher. Either I was missing a step, or it is because I am using the Universal Launcher, not the stock one.
Universal launcher didn’t work out for me well so I stayed on stock one. If you want to try with SwipePad (it works with every launcher) you can follow these steps:
Install Vysor on your computer and connect watch
Install SwipePad
Go to Macrodroid and add “Shortcut Launched” trigger to your brightness macro.
Configure hot spot for SwipePad launcher to start
Configure default pad
Click chosen portal
Choose green arrow with “Shortcuts”
Find Macrodroid icon
Choose your macro and OK
Choose the icon for the shortcut
Now important: click in the bottom of the Vysor screen
Now you should be fine. When you touch hot spot on your watch and swipe to macro shortcut the macro will fire.
Here are screens from SwipePad configuration:
That worked like a charm and Vysor is real handy application! I am still getting a massive battery drain, but have installed an app to help me tie down what is causing it. You have really gone above and beyond to help me with this. I am sure others are also interested in what you have done here, and you are a real asset to this forum!
Hi
Is 20181217 the newest fw? Still no ota updates for me.
Hi ladies & gents,
a simple question : the stock dialer doesn’t seems to allow to “fusion” calls. I installed others dialers (Truephone…) but when trying to make a conference call, i still can’t find any menu to do this.
Any app / solution to share?
Thx,
Nicolas
When I try to connect wifi (authenication problem).Cant connect to playstore or browser or weather app. HELP
Have no sound on notification.
Have no notification about the calls.
Also when I receive notification I can only dismiss and I can’t read it.
Thanks all
Denis
I have exactly same problem But I use Huawey Mate 20 Pro.Have no sound on notification.
Also when I receive notification I can only dismiss and I can’t read it.Thanks all
Denis
Mar 11, 2019 13:43:53 GMT 2 sunpaladin said:
Hi ladies & gents, a simple question : the stock dialer doesn't seems to allow to "fusion" calls. I installed others dialers (Truephone...) but when trying to make a conference call, i still can't find any menu to do this. Any app / solution to share?Thx,
Nicolas
