Nov 30, 2018 8:34:02 GMT 1RASC Moderators said: Everyone - I strongly recommend that you update to 20181113 Firmware.
It has new screen wake sensor driver and it is MUCH better
Dec 4, 2018 5:08:29 GMT 1karthikborkar said: New update drains lot of battery with gestures screen on sensor and it’s way to sensitive. Slight movement of the hand screen turns on.
Did you use firmware upgrade when you flashed or download only?
Factory reset it.
I don’t have this problem at all so far. I’ve had it since the day it was made - the update I mean.
Used download only option and did a factory reset.
I’ll give it couple of more days
Dec 4, 2018 5:34:36 GMT 1pablo11 said:
I must admit that I always use the firmware upgrade option if I'm flashing new firmware for the same model watch.
Because it removes all traces of the previous version.
At first I thought it was draining the battery quickly too but it has settled down and now I get better battery life than before. It took a couple of recharge cycles for this to happen. I have the gesture on and I think it’s just slightly better than it was but not sensitive.
Dec 4, 2018 7:15:43 GMT 1rickinsd said: At first I thought it was draining the battery quickly too but it has settled down and now I get better battery life than before. It took a couple of recharge cycles for this to happen. I have the gesture on and I think it's just slightly better than it was but not sensitive.
Yep, it's improved but not sensitive.
I agree with that.
About gesture, i’ve noticed that too. Just a question, do you know if there is a new update on the work or the one on 18/11/13 will be the last available for a long time?
I don’t know of anything that would block the installation of Vysor unless you have not allowed “install from unknown sources” in the watch security settings.
Once usb debugging is enabled and the security setting is done - there is no reason why install would fail.
I eventually got round to fixing this… I didn’t do a factory reset after an OTA upgrade… when I did I could use vysor with no problems.
I have a problem to share with you.
In my car, I hang the watch over the console to use & see Waze. I put the watch in charge at the same time.
Temperature is “normal” in the car (Belgium isn’t a warm country), but within the next 20 minutes, I keep getting a warning message about overheating problem.
Okay the watch is warm, but it is far from being so hot it could be a problem in my opinion.
I may discard the message, but a few minutes later the watch will shut down & reboot.
Conclusion : I can’t use Waze. Please note that no other apps are running in the background.
Questions :
Did you experienced this?
Do you have workarounds to share?
Dec 19, 2018 11:40:39 GMT 1p3pp8 said: Hello, just a question, I'd like to create a custom watch face for my LEMX, is there any resource where to learn how to make it?
Thanx in advance!
Thanx in advance!
