lemfo lem x
Everyone - I strongly recommend that you update to 20181113 Firmware.
It has new screen wake sensor driver and it is MUCH better
It is here /thread/2673/lemfo-lemx-m6739
Nov 29, 2018 23:53:28 GMT 1 promethian said:
I tried Vysor out but when connecting to widows pc got an error message on phone, that said permission was obscured by another app and was unable connect. I did enable USB debugging etc
You should keep the screen on while you install Vysor from PC to the watch.
Phone has nothing to do with Vysor.
It should be installed on your PC and use a USB cable to connect to your watch.
You should keep the screen on while you install Vysor from PC to the watch. Phone has nothing to do with Vysor. It should be installed on your PC and use a USB cable to connect to your watch.
Sorry typed phone instead of watch... I meant watch.
promethian
I don’t know of anything that would block the installation of Vysor unless you have not allowed “install from unknown sources” in the watch security settings.
Once usb debugging is enabled and the security setting is done - there is no reason why install would fail.
Nov 30, 2018 8:34:02 GMT 1 RASC Moderators said:
Everyone - I strongly recommend that you update to 20181113 Firmware. It has new screen wake sensor driver and it is MUCH better
Did you know that they change the screen resolution or it’s on my watch the new one is 640x640 and it’s supposed to be 640x590 correct if I am wrong and the icons before they were showing in the right side of screen and right now after the two update using SP flash tool they are showing in the left side. Trying to use a 3 party app to change the DPI and the screen resolution did you have some ideas or you can talk to Lemfo to try a little bit more to get the ideal DPI and resolution because it’s really hard to click tha “OK” bottom, besides that the watch is great, but???.
leafar
I will find out.
I had not noticed this… :thinking:
anyone can suggest to a newbie what is the right procedure to flash the new firmware without bricking the smartwatch? I’ve already installed VCOM drivers correctly, the SP Flash tool loads the new firmware right away, but, how is supposed to continue? Do i have to turn off the smartwatch and than click on download button, or do i’ve to disconnect the smartwatch click on download and than connect it to my PC? Any suggestion or guide link is really appreciated. Honestly the rise to screen on feature is importart to me, i’d like to test this new firmware. Thanx in advance guys!
Dec 1, 2018 8:45:34 GMT 1 p3pp8 said:
anyone can suggest to a newbie what is the right procedure to flash the new firmware without bricking the smartwatch? I've already installed VCOM drivers correctly, the SP Flash tool loads the new firmware right away, but, how is supposed to continue? Do i have to turn off the smartwatch and than click on download button, or do i've to disconnect the smartwatch click on download and than connect it to my PC? Any suggestion or guide link is really appreciated. Honestly the rise to screen on feature is importart to me, i'd like to test this new firmware. Thanx in advance guys!
Go to our YouTube channel and watch the video. The link is posted at the top of the forum.
pablo11 Thanx!
Dec 1, 2018 8:48:46 GMT 1 p3pp8 said:pablo11 Thanx!
No problem 👍👍🤝
Is it normal that everytime there is a firmware update to be flashed - that all previous settings/apps/ info is lost afterwards? I’m suffering from new watch deja vue!
Dec 1, 2018 10:48:29 GMT 1 aronl said:
Hi, Is it normal that everytime there is a firmware update to be flashed - that all previous settings/apps/ info is lost afterwards? I'm suffering from new watch deja vue!
Yes, that is normal.
OTA does not wipe anything but you should factory reset after OTA so it gets wiped anyway.
I did it, fast and easy, thanx! Great community, great watches! Thanx again pablo11!
p3pp8
Very happy to help.
That’s why we are here :+1::slightly_smiling_face:
Hi guys,
here is my problem of the day :
I’m using the lemX with Nova launcher. So it looks more or less like a common smartphone interface. Great so far as full smartphone replacement…
But today I added my work account, and the internal policy enforces the use of a password. I’m okay with that, so I choosed one and i’m now typing a pw to unlock the watch.
My problem : I don’t know how I can access the security management menu you can find on a smartphone trough setings>security (To choose / change pw, pin code, swipe…). Altough I know it exists “somewhere”.
My question : how can i access the security menu?
thanks,
Nicolas
Dec 2, 2018 18:19:22 GMT 1 sunpaladin said:
Hi guys,
thanks,
Nicolas
install this appplay.google.com/store/apps/details?id=com.google.android.apps.gesturesearch  and just write security and it will take you there, make sure to leave security on recent apps( do’nt reset that) for future needs:)
That play.google link didn’t work for me. What is the app?
Dec 3, 2018 7:31:38 GMT 1 ticktock said:
That play.google link didn't work for me. What is the app?
Google Gesture Search
Hi guys,
thanks,
Nicolas
Great, thx !
