Sept 13, 2018 6:39:38 GMT 1giugiu said: Thanks a lot Pablo. I hope there will be a solution. This function is the reason why I choosed this model. I suppose I am not the only one
Just got a response about this from LEMFO.
It has been disabled for now due to the metal bezel causing interference with the pinch to zoom action.
I am looking at options and talking to them about it.
Their answer is strange. Indeed I remember when I had my Les1. Mine was multitouch and some not. The bezel was not in metal ?!?
No, it is understandable…
I tested the pre-production model where it was enabled and the metal bezel was causing the capacitive field to have a jerky response.
We’ll see if there is anything that can be done.
can you tell me plz what is the date of your firmware, you should get at least 15hrs of usage and without most connectivities on you should get even more than that.
movieifx
Have you already tried a factory reset?
If you have done this and it is still not good - you can flash the firmware using the “Firmware Upgrade” option in the SP Flash Tool.
That should wipe the watch completely and start fresh. Make sure you do NOT select the format + download option!
So this problems, no good design and they figure out later that is the small metal bezel how come it doesn’t make sense is a big screen, I hope in feature update it will be resolve.
Sept 13, 2018 15:47:58 GMT 1pablo11 said:movieifx
If you have done this and it is still not good - you can flash the firmware using the "Firmware Upgrade" option in the SP Flash Tool.
It is not normal for battery life to be poor.
I will try factory reset though I only have stock apps on. Do you have link to firmware to download for use with flash tool ? I have used tool before this is my 4th android smartwatch.
Anyone point me to compatible USB charge cables for lemx. Its my 4th watch with yet another different charge cable/cradle. Lemfo UK who I bought watch from have quoted £10 which seems a bit steep ?
Fully charged and did factory reset whilst connected to charger. Following day left WiFi, Bluetooth and step counter on all day. Made calls and updated apps during day and still had 51% left after 16 hours!!! That’s more like it. Will try adding apps and faces now.
Hi I have version : DMN_DM19_LEMX_20180830. The battery life is really awesome. Unfortunately the multitouch is disabled .
Nevertheless this is the first Chinese Smartwatch With a 100% functional Gps. And I have tested a lot of (les1, dm98, d5,d7, z80, …)
that is the last update, reset the watch make full charge and see how the watch battery behave, i get way better battery life and i use it fully with 3g\gps 24\7 with activities app.
Hello
Yesterday my lemx arrived.
Very good so far.
In the past i work with join to synch messages.
On my lg g6 join works - but on the lemx not.
Only with wifi it works.
On 3g/lte it says no connection to gcm server
Possible ports blocked.
Any ideas?
Sorry for my bad english
Hope someone can help
