lemfo lem x
Sept 8, 2018 12:13:15 GMT 1 alt68 said:
will do:) you gave me another idea for more videos.
Sept 8, 2018 2:56:30 GMT 1 soniasophie9697 said:
Sept 7, 2018 6:26:35 GMT 1 movieifx said:
Solved data problem this morning. Obviously too tired last night. Strange thing is with previous watches, they all had in setting - connect option to turn data on. It just isn’t there on this watch. The only way is to click on the shortcut on/off icon with 2 curved arrow lines that is for mobile data. Seems an omission that its not in the usual place as a tick box for mobile data.
it is there, on cellular network - you have two option via the connectivities bar or the settings:)
If I go into settings - cellular network I get following options
Data roaming on/off
Preferred networks
Preferred network type
Enhanced 4g LTE mode on/off
Access point names
Network operators
None of the above can be used to turn mobile data on/off.
My firmware build is 30th August 2018 which I assume is latest ?
Screen on raising has a bit of a delay. Takes 3 seconds from raising to screen coming on.
yes, FW team still works on it, turn on roaming data, and make sure that data is on , go to watchface - slide down - slide left and there you should see the data connection is on (arrows up and down).
I didnt see mr ticks video on youtube, isnt he public anymore?
His You Tube page is "Smartwatch Ticks".
Sept 9, 2018 18:53:06 GMT 1 giugiu said:
And he tested the watch under : lemx instead of Lem x
Sorry what I meant was I did a search for lem x and that didnt show so I was asking if he only stream to subscribers now
Hi. Yes that#s what I meant in my post above. Sliding to those up and down arrows is only way to turn data on and off. Previous watches it was essentially a shortcut in addition to an option in the actual settings menu. No worries though at least it’s there.
Good to know FW is being worked on. I’ve turned this feature off for now. I do have concerns over battery life. I’m just using standard apps and usage patterns in same way as my previous zeblaze thor, the Lem x seems to struggle with battery more than thor even with it’s tiny battery. I suspect culprit maybe step count so will try some days with that off.
Example so far today with step counter on, dropped from 100% to 68% in 5 hours with no wifi or 4g on at all in that time. Bluetooth is on though which seems to account for 13% - seems much higher than thor’s usage was, going to turn that off for the rest of the day.
movieifx
can you tell me plz what is the date of your firmware, you should get at least 15hrs of usage and without most connectivities on you should get even more than that.
I can leave my cell data on all the time and still get over 15 hours if I don’t smash it.
I use the account sync settings to stop stuff syncing that I don’t need.
Then I use the data restriction settings to stop any unwanted apps from accessing network all the time.
Add the power saving settings into the mix and its a great result.
Of course, if you don’t need 4G data speeds - leave the watch set to 3G.
This also helps a lot.
Jul 30, 2018 2:17:30 GMT 1 krapulant said:
Jul 29, 2018 20:26:48 GMT 1 soniasophie9697 said:
wow that is one amazing watch it has what ALL users want:) big screen with great resolution , big battery, 4g capability, andorid 7.1 even the camera was upgraded:
www.aliexpress.com/item/LEMFO-LEM-X-Android-7-1-4G-2-03-Inch-900Mah-8MP-Camera-Ip67-Waterproof-Luxury/32901511832.html?spm=2114.search0104.3.2.7b623b8dlcYnEl&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10065_10151_10344_10068_10869_10342_10868_10343_10340_10059_10341_10696_100031_10084_10083_10103_10618_10624_10307_10623_10622_10621_10620,searchweb201603_6,ppcSwitch_4&algo_expid=311f2e13-8c80-43c8-847e-a656a76f0b07-0&algo_pvid=311f2e13-8c80-43c8-847e-a656a76f0b07&priceBeautifyAB=0
what do you think?
It would be a GREAT watch if it’s properly supported by you guys. I’ll put my money on it when the first units have shipped and reviewed and if it’s supported by this community.
Resolution is really good for this form factor (640*590) which would allow a more ‘natural’ look… Heck, some cheap smartphones are using resolutions in those numbers… The bezel is really slim!
Supporting bands 2/7/12 is a GREAT thing for Canadian users on Bell and Telus. However, without support for Bands4, there are large gaps in the couverage that will fallback to WCDMA.
Sept 12, 2018 19:23:36 GMT 1 giugiu said:
Sept 12, 2018 13:35:15 GMT 1 martin2162 said:
Hi. Received mine today. Very beautiful but very upset too .
Indeed I absolutely wanted the multitouch function. And as seen as on various YouTube test, it was multitouch. But mine not .
I don’t understand. The firmware date is August 30. Please help
Mine works on Google Map for exemple, not sure it works on much apps…
Eric is exactly right.
It is multi touch if the app you are using supports it.
Sept 13, 2018 5:43:28 GMT 1 giugiu said:
Hmm, this is strange. I will test again and let you know.
It’s not working on picture.
Yep, confirmed.
It seems that the latest firmware 20180830 has disabled it.
Can’t get it to work on Maps or photos.
I am following up about what has happened.
