LEMFO LEM 5 dont start after Firmware
I could dive some help, I have install on my Lemfo LEM 5 another firmware , now the clock does not start anymore. I disconnected the battery from the clock and connected again on the hope that it will work again. Is there a way to fix this problem?
Sorry for my bad englisch
Have you tried to flash again another official FW ? which flash option have you taken ?
We need details.
Jan 27, 2018 14:32:34 GMT 1 druss1981 said:
do as  been suggested and flash it with official firmware, you can't flash it just with any firmware you need to be sure first if it suits your watch or not and as you can see it bricked the watch, hopefully flashing it back with it's firmware will fix it.
Nö i dont try a official one. Where can i get one?.
And i used the flash tool
here:     /board/16/factory-firmware-downloads
THX i try it. I send a report.
Ok i think The Watch is damaged… There comes a Windows with
BROM ERROR: S_FT_ENABLE_DREAM_FAIL (4032)
[EMI]Enable Steam Failed!
[HINT]:
Pleased check your load matches to your target wich is to be downloaded.
Jan 28, 2018 9:00:15 GMT 1 druss1981 said:
what is the model of the watch? open it and it should be on the inside of the watch.
W618_MB_V1.0 is this the right one?
ok, and which firmware did you try? your watch is the 1gb ram and 8gb storage right? or the pro?
Jes The one with 1GB. I try The Firmware w618_wgl.lemfo_ddr3.common.80emmc.w.s.170306-124543, nur im not realy Sure.
give a link to where you downloaded from.
Puh ich think ist was from Here.
i need the exact link to see what you've tried, the question is the w616 or the w618 and if you did flash the w618 then it should have been ok, but seems you flashed the worng one, so i need the link for what you've used.
I dont know where exatly i downloadet IT. But this is the Data.
drive.google.com/file/d/1V4JyNmtxseGFQF_SmavpRcxyHv4g705q/view?usp=drivesdk
ok, i’m most certain this is’nt our source cos we use Mega, we do’nt have the w618 of the lem5 firmware but for now you can use the x5+ firmware which suits your watch and i’ll see if we can get the lem5 w618 firmware basically the x5+ and the lem5 are the same watch.
/thread/543/w618-version-firmware-watches-memory
Ok THX i try it tomorrow and tell you 2hat Happen.
omg my clock is alive again, but now I have a finow: D. the problem why I wanted to update the clock was a battery problem. my battery discharged drastically and I hoped for improvement. do you have any idea or maybe the problem is resolved with it? First of all many, many thanks for the help.
honestly i think with the mtk6580 the x series and it's like with 3g they have carpy battery life which i do'nt have with the kw\ H\ and  the I series. try discharge and recharge from 0% to 100% at least once and after that make sure never to leave the watch in charge for more than it needed to be.
