from the charging cable of a lef2 came the usb connector off. Has somebody a link to order a new one? I could not find anything on Ali. Is there another way to charge the watch like for the other models from Lemfo something like a docking station and using a normal USB cable?
The description also tells you that it works with the Lem4, LF16, KW88, KW18, LF17, K88H. I have a KW18 and if it works with that watch it will work with others.
Thanks capt jon for your answer. Yes I search the internet and I saw this cable and contacted the seller but no response so far. According to the connectors, this is not the right cable. Also, is a difference between the KW88 etc. and the lef2 watch connectors.
I’ve found the same on Ali but the told me they don’t have the correct one.
Jan 31, 2019 17:41:58 GMThans65 said: Thanks capt jon for your answer. Yes I search the internet and I saw this cable and contacted the seller but no response so far. According to the connectors, this is not the right cable. Also, is a difference between the KW88 etc. and the lef2 watch connectors.
Just trying to help. Not sure if you found this page on ebay, it differs from the other link I posted because it lets you select the specific cable for each watch listed.
