LEM5 Pro mod firmware for X5+ / X5 Air / LEM5 / LEM5 Pro
Follow the solutions provided by this thread at your own risk.
This ROM is suitable for:
Lemfo Lem5
Lemfo Lem5 pro
Finow X5 plus
Finow X5 Air
14.07.2018 lem5pro_mod_by_Vell_m11.1_full
  • based on the firmware v.s.180521 (This firmware have a Bluetooth Call).
  • changed bootlogo
  • bootanimation in WearOS style
  • patched boot.img (ADB without request, does not kill TWRP)
  • the firmware has a factory odexation
  • removed OTA update application
  • removed GAPPS
  • the default language is Russian
  • the default time zone is Moscow
  • engineering menu in the developer menu
  • replaced font in MzLemfoLauncher2
  • Screen shutdown timeouts changed to 5с, 10с, 15с, 30с, 1ΠΌΠΈΠ½, 5ΠΌΠΈΠ½, 15ΠΌΠΈΠ½, 30ΠΌΠΈΠ½, 1час.
  • by default, palming bright screen i on
  • by default, when you go to sleep, the network must not be turned off (def_off_screen_off_net = 0)
  • add RoundCalc app
  • add Watch Droid Assistant app
  • extended set of dials
  • Items added to advanced settings
    . . battery stats
    . . apps
    . . administrators
    Not worked:
  • I could not get internet via Bluetooth from my phone
Changelog and other information in My original post on 4PDA (Russian language only)
so we can change ro from now on?
you know, just spent 3 days for reading needrd forums to be able to deodexing the firmware, to correct a couple of resources, and write a setup script
And, Yes, we can change the rom.
What does it change in working of smartwatch? Is it better/faster?
Jun 19, 2017 21:28:51 GMT 1 vell said:
x5plus_mod_deodex_170619_Vell_SPFT.zip - firmware for SPFlashtool MD5: 7a176051746a180cb4ce1c3aec9874df
x5plus_mod_deodex_170619_Vell_TWRP.zip - firmware for TWRP
MD5: d4e75c10b79275cd7f748fc755a78b38
Changelog:
19.06.2017
this is a modification of the firmware w618_wgl.x5plus_ddr3.common.80.emmc.w.s.170327.flash
Changes:
  • deodex
  • GAPPS deleted
  • change font in MzLauncher2
  • Russian translaton MzLauncher2 by Π”Π΅ΠΉΠΌΠΎΠ½
Tested and works well. It seems that the battery is better.
probably because disabled google services
is it worth flashing for battery life or not
can someone help me to instal the firmware in my Lem5… some video or something
drive.google.com/file/d/1aCRxD-QyWXe72KpHzHAdgWJPWtR0b75j/view will this one work on Lemfo LEM5 PRO?
Changelog:
19.06.2017
This is a modification of the firmware w618_wgl.x5plus_ddr3.common.80.emmc.w.s.170327.flash
Firmware is suitable for Finow X5+ and Lemfo LEM5, w616 and w618
Changes:
  • patched boot.img (init.d support, unsecure ADB, no restore stock recovery)
  • to support init.d need root and busybox (set lead)
  • deodex
  • removed updater app
  • removed GAPPS
  • removed Chinese keyboard
  • change font in MzLauncher2 (For Russian translation)
  • engineer mode in developer menu
  • changed the screen timeouts 5s, 15s, 30s, 1min, 5min, 15min, 30min.
Nov 17, 2017 3:55:53 GMT 1 leocris said:
can someone help me to instal the firmware in my Lem5... some video or something
you need to be sure that you know what you are doing, make sure that your lem5 is the same model as the x5+!! btw, you can just root the watch and disable google services and sync, updates and you'll get great battery life.
no, they are two different models, why? if i'm not mistaken the x5 air and yours are the same model and if so you can flash it with this firmware , do you have issues with your watch?
updated version works on Lemfo Lem5 Lemfo Lem5 pro Finow X5 plus Finow X5 Air
see 1st post
see 1st post
On your new firmware x5air_mod_by_Vell_v0.03_full/x5air_mod_by_Vell_v0.04_full how do i change the cpu configuration back to stock?
see 1st post
Nvm i got it.
Install this patch drive.google.com/file/d/1SKTddIJeabXN14ynJc1tHj25yo6hZy7r/view
Hi
version of my watch finow x5 air-v.s.171206-1512528792 . Can I upload it?
hi guys
i have a Finow X5 Air
in order to flash the wath i need to select just the already selected flash voices (as boot, recovery…) are i need to select all ?
thanks
boot, recovery and system.
no need to flash all blocks
Jan 5, 2018 14:25:11 GMT 1 vell said:
boot, recovery and system. no need to flash all blocks
Thanks Dude,
but  Flasher does not connect to my watch.
I am not familiar with that stuff… i would like just to root the watch to gain SU rights as well to fix GPS.
any help to give me ?
Luca
Dec 5, 2017 9:11:26 GMT 1 soniasophie9697 said:
btw, you can just root the watch and disable google services and sync, updates and you’ll get great battery life.
Really? How you do that?
