Hi, I am new at this forum, so I want to greet its members.
A few months ago I bought a LEM5 Pro as the first contact with this kind of smartwatches.
The program of notifications of Lemfo, Watch Helper is disastrous and useless, reason why I installed Watch Droid, with very good results.
BUT there has been an OTA firmware update (180129-1517208688), which has created a significant problem of Bluetooth instability, to the point of making it impossible to use (constant on / off cycles).
Thanks to this forum (especially to soniasophie9697), I was able to reinstall the previous stable version, and I was able to recover the functionality of the clock.
That’s why I recommend not updating your LEM5 Pro until the BT problems are solved, if you need it.
Hello,
you must uninstall Lemfo App in your Smartphone and download it again from QR Code from the Smartwatch.
Install it into your Smartphone, and it will be OK.
Problem solved…
Mar 7, 2018 23:12:31 GMT 1murat said: Could you please explain where I can download the first stock stable firmware and how I can flash this? Because I have excactly the same problem
After this update the bluetooth keeps disconnecting and reconnecting. I would really appreciate ir if someone can give a link of the stock rom and little instruction to flash.
open the back of your watch and see if it says w616 or w618 and i see what can be done. for now you can flash it with the stock firmware of the x5+ but you need to be sure first of your model or you’ll brick the watch.
good day friends, I have a problem when current process flashing lem5 pro w618 using spflash tools having problems Brom error: s_ft_enable_dram_fail. please help thanks
Apr 2, 2018 10:45:02 GMT 1iwanr32 said: good day friends, I have a problem when current process flashing lem5 pro w618 using spflash tools having problems Brom error: s_ft_enable_dram_fail. please help thanks
are you sure that you flashed the right firmware for the watch?
