Lem5 notification problems
Hi, to have someone help me. I can not run any application to have bluetooth notifications, I have tried m2d but it has many problems, smartwear does not connect the clock, notisync does not show notifications etc. I have a lem5, does any user of this watch run any application?
OBER, Hello, we both wear the LEM5,
since i know, you can´t use smartwear with lem5, it have Android 5.1
I first installed the "watch assistant in my cell pone, at second time it rules “fine”
have you made sure to make the passwords the same on both devices? have you used the bt app? try not to install any popups notifications apps just the m2d.
Smartwear is an application that is in google play, which serves to link android mobiles. Sonia all passwords are fine. Another problem of m2d is that the screen turns black. Thanks for your answers.
Another problem more than m2d is that I can not change notifications, when I have more than one, for example, I have to delete the last whatsapp to see the previous one.
reset the apps and try again black screen means u chose tablet or phone as screen option i did it also by mistake.
You need to use square mode to be able to move through the notifications from m2d in the lem5 . Seems like it doesn't recognize gestures otherwise It is anoying because it is much uglier and smaller but I couln't find a solution yet.
Another problem is that when you write you can’t see what you type because the letters and the background are the same color
Solved the problem of synchronization, I get the messages. thanks to all.
Paco, toma nota del problema en lem5, haber si en la proxima actualizacion lo puedes solventar. Gracias.
are you sure that it does’nt work with round display? did you choose smartwatch or tablet\phone?
You need to use square mode to be able to move through the notifications from m2d in the lem5 . Seems like it doesn’t recognize gestures otherwise
It is anoying because it is much uglier and smaller but I couln’t find a solution yet.
I choose smartwatch. I read in youtube and somewhere else in the forum the same problem with the lem5.
