Nov 24, 2017 21:56:23 GMT 1 nlb said:
Hi,seb84. At first i think make one new back plate,but its not simple..i mean laser cut spacer maybay easy way to go..but than the sensor cables maybay must change to longer ones..?? I think the 40x40 square size its too big for my D5+..my original battery size is 453535 450mah round.. But i found a nice one: m.alibaba.com/product/60610085548/round-lipo-battery-3-7v-1160mah.html?spm=a2706.amp_sc_detail.item_details Its 553535..i dont know how its possible,because in this size(553535) on the net i found only 580mah.. 580=128,88%(not bad) But if work and really 1160,its= 257,77% If i understand correctly,difference between 453535 and 553535 its +1mm high.. My idea is go to watch repair/master,who have see/repair analog and digital watches,and talk with him about what we can do..
yes, i saw the same attery already too. i just thought 28% up is too smll, to give me what i really want (work with the watch all day).
but the 580 will definetly fit inside. there is enough space. for the one i ordered, there will be a lot of mods to do. i wil post a guide here next week if i can make it fit.
cables might really be a problem, but will have to see when its delivered (still watiting by now).
you can swap the 580 easily if you see the pics. just buy a small screwdriver with magnetic top (some of the screws are located a little deep inside the case).
but its quite easy to open.
you understand the difference on the batteries right first value 45 = 4,5mm second and third value 35 = 35mm)
the 40 mm of the 1200mAh one i ordered will fit, its just about the height (7.5mm) that will make a problem. the board height inside is only 6mm (measured from the display to the board) so i’ll need to find 1.5 mm somewhere (if i can make the cables fit, i will just make an adapter, like you say most probably laser cut (the shop is ver near to my home)
