No se si alguien me puede ayudar. Al insertar la tarjeta SIM en el teléfono se bloquea la pantalla tactil. No puedo usar la pantalla no funciona. He probado a colocar la sim en el móvil y ahí funciona correctamente. Gracias
plz, in English, i do'nt understand:)
I do not now if someone can support me. When the SIM card is inserted in the phone, the touch screen is locked. I can not use the screen does not work. I have tried to place the sim on the mobile and it works correctly. Thank you
Did you turn the phone off before inserting the Sim Card? Also is it inserted correctly, some watches it can be put in backwards with a little effort. Does the watch work correctly without the Sim Card installed. A bit more information would help resolve your problem. Thanks
1. the sim has lock pin 2. there is an issu e with imei
can you check the sim with different phone?
can you check your imei? #06#
