LEM5 dead. help. please.
1-I,ve switched on without the bottom tap closed. then the screen lights, but never response to any tips.
2- After installing a MT6739_Android_Scattler that Lemfo web assistant sends me.my LEM5 is dead¡¡
3- please help. now it didn,show nothing, nor charging battery
I am struggling to understand your problem . Have you flashed the firmware and it has gone wrong ? If so watch our youtube video and do it again . Make sure you have the correct firmware .
Did a quick search and found this. It shows it runs a MTK6580 processor running Android 5.1. So if he flashed MT6739 firmware don’t you have a problem?
Reading the original post i wouldnt like to fully guess what he has done . As you know with flashing you cannot make any mistakes . We shall see
Thank you Guys.
just only one question:
Now, the watch seems to be dead¡: ( no charging, no flashing, no react at USB conection…)
therefore…, is there are any thing i can do??
and whuch one and where? is the correct firmware i Should use??
Try cleaning the charging pins with a small amount of alcohol .
