deep sleep is never used ? after activating deep sleep have a higher battery use in standby
anybody experiencing the same? is it the radio that can not shut down?
using e-robot and secure settings i can shu down 3g on display off, but don’t get it on when display turn on (have to do manually, e-robot command will fail)
Had the same experiences with tasker and/or juice defender. Now I use xposed (with root) and “smart network”-module, it seems working. There is also “greenify” to force deep sleep, that can use xposed for more functionality.
i use greenify with exposed.
will try the smart network module. thx for that.
anyhow the deepsleep is stated as never used. i don’t force it to ds, while like i say, i had a higher battery usage afterwards. most apps are hibernated though
I also had this an other strange behaviours. After flashing a firmware from here, it works better. Less of this shitty small problems. So maybe it is the way to go. You should beware of flashing the w616 or w618 firmware. The wrong one will not work and untick the “boot” part.
Aug 23, 2017 11:53:12 GMT 1chromax said: I also had this an other strange behaviours. After flashing a firmware from here, it works better. Less of this shitty small problems. So maybe it is the way to go. You should beware of flashing the w616 or w618 firmware. The wrong one will not work and untick the "boot" part.
which fw do you run? i have 618 chipset. i still use the original fw, but i also have to say, that despite deep sleep, its running mostly stable and fine version 1700306
if i'm not mistaken you need something called cpu mangager, btw, how did you root your watch? if you used kingroot you bettr remove any apps related to it from the watch and use supersu cos it drains the battery.
you can do so with ds battery saver e.g. also some other apps will do it. i tried to achive this with greenify, but deep sleep will not be used, even all apps are greenified.
BUT BE AWARE: after activating deep sleep on the lemfo, i had a HIGHER battery usage during standby.
i than switched back to normal greenifying options, as described earlier in the thread (i got the best result with this).
so if you experience the same, better switch to exposed with greenify (most options), an additional boot controller (like clean master with root, or all in one toolbox), here you can take off some entries from the startup (save time and energy).
i tried also kernel audiutor, but couldn’t deactivate cores, let me know if you have more success.
last but not least, i used e-robot and secure settings, to automize sync. and as discussed earlier to de-/activate 3g connection (i think most will prefer tasker over e-robot, but i like the interface and its free), you can do also some oher funny stuff with this. follow through my threads
i used “repair battery life pro” and had very good reslts with it on many devices (asus zenfone 5, battery was like dead, works well now / asus zenfone 2, smaller improvement and the lemfo, with a big improvement too).
please ignore this last one, if you don’t like those apps (somebody here called it spam earlier)
