how do you connect LEM14 and a PC , I do not understand
MERCI
MERCI
Connect watch to Pc with supplied cable . In watch open settings , connections , usb and select file transfer if thats what you require .
If your Pc needs a driver installed its in this folder ( ignore the other items in folder )
thank you but unfortunately there is no cable
How do you charge your watch?
Do you have a charging dock instead? This might work, too.
thank you all this works now merci =)
