**HI i dont see my LEM 14 on VYSOR !! why ??
Thank you . Merci**
Thank you . Merci**
have you turned on USB debugging in the developer settings?
ok, but where is it on LEM14 ?? Here is my problem =)
Thks. Merci
first go to settings > about phone / watch and press fast about 5 times on the build number, then go back and to system > developer options
thank you very much you are very kind ! Merci beaucoup
