with mobile the site of lemfo on aliexpress works normally.
On pc nothing works.
Your link also works but only on mobile.
No need for pics all good thanks. Disconnected power OK. Just taking time to reconnect as very fiddly, but I am sure I will get there
The scary thing is reconnecting without causing any short.
Take care and use a magnifier to help you see properly
Hello,
Is there a way to see whether the external battery is charged? Os whether it is charging?
GL
Yes you can use an inline Volt/Amp meter that measures the voltage and amount of current flowing to the battery. I use this one I found at BangGood.
ok, this day was like this:
12 hours of use, 2-3 phone calls, now the battery is 9%.
I say, its better but Iām not very happy. Lets hope, that there will be some improvement in the near future
Thank you @Alexcomrad and also @Jonathan_Bickel
Hi all. For info here is the inside of the watch. Just 4 screws to remove back cover (no wires are attached to the cover), then 2 screw to access the rest. Be great if the battery shape could be moulded into all the free space, then the watch would not be so fat at 17 mm. And sorry I did not record the battery specs printed on it when I had it outā¦
Thanks very much
Always really appreciate photosā¦
Glad you worked it out ok.
I always take of the very thin rubber gasket that normally fits around the edge of the rear cover.
But not all watches have one⦠Not sure why either
Anyway, thanks again and hopefully I will post my photos soon as well
Hi guys,
I am new to this forum and I just received a LEMFO LEM12 PRO.
Quick first question:
Is there any way to define a user-specific function for pressing the lower or upper button, once, twice or for e.g. one second?
And second question:
Is there also a possibility to have widgets on for example the watch face? I am looking for an easy way to record audio by simply pressing a widget button and not searching the app in the first place everytime I want to record a quick thought.
Thanks in advance! And pablo11, thanks for this thread! Your V06 saved my day after receiving the watch and crashing the firmware somehow after only 15 minutesā¦
Kornelius
There is an App called Buton Mapper, with which the buttons can be reassigned. Widgets on watchfaces, however, are not possible. However, shorcuts on watchfaces. If you use the universal launcher, you can place widgets under the watchface. Then the watchface only has to be swiped upwards.
Another Option, that I use, is Smart Touch Pro app. As in the picture it only displays a button on the screen, you have several styles to choose from. When you tap on it, you get the display that you set up to access I believe up to 16 actions or apps. The best thing is it displays over every screen, even when in power save mode, so you donāt have to go back to the main page to access it. For example it is very useful for taking screen shots while on the page or access your record function from any app.
Seems to be an interesting watch just bought lem 12 pro will see how it goes ā¦
I couldnt find any topic here . Do allrods watchfaces run on the LEM 12 pro ?
Thanks guys! Button Mapper actually did the trick. All solutions giving me some kind of a āwidgetā are not really satisfying to me⦠or they draw a lot of battery.
Other question:
Usually when I develop Android apps in Android Studio, I debug the app directly on-the-fly on my device. Does anybody know how I can activate Debug Mode on Lem12 Pro once itās connected to my PC?
Thanks guys and best regards
Kornelius
Some will , some will need the .xml file adjusting depending on the clockskin features .
same way you would do it on other devices I guess
The clock is dead. I put it on charge overnight. In the morning I took off the exercise, and they are hot as an iron. The watch no longer turns on and does not respond to buttons.
Put it in the refrigerator
Should not leave on charge all night.
Should be a thermal cut off.
Make it cold
They have cooled down for a long time, but nothing has changed.
