Not sure what I did, it’s probably simple but it’s like the clock face is off to the left and I can’t get it to center and fill the screen. Adding pics that may help…
It looks like your watch is set to square mode! Press the button on the side of the watch, and hold it down for a few seconds. A menu will pop up with options to shut down, restart, etc. Above that, tap on an icon that looks like a square with a circle around it. It will turn into a solid white round dot, and then your watch will be back to normal!
And you will have to restart the launcher or the watch…
me too
Apr 19, 2019 0:21:20 GMT thecharliemac said:
Not sure what I did, it's probably simple but it's like the clock face is off to the left and I can't get it to center and fill the screen. Adding pics that may help...
how to past the photo
I had already reset the phone and checked if the watch was set to round or square, thanks for the suggestions! I had to remove the launcher and reinstall. It is working fine now. Yay!
