I’ve been using my LEM T, albeit occasionally, without problems for three years. Generally I charge the battery once a month when not in use for several weeks. Three weeks ago the watch refused to turn on whatever I did, so I suspected a discharged battery. Charging had no effect, even cleaning the 4 pins of the charging cable and the receptacle pins didn’t solve the problem. I removed the back case of the LEM T using a size J0 screwdriver and noticed minuscule particles of dirt on the charging pins inside. After cleaning these, the watch works perfectly again!
Great feedback. Thankyou
