Hello everybody!
I have a Lem 14 smartwatch to update. What do you advise me to do today?
Why do you have to update?
The Wiiwatch application does not sync correctly.
Where can I put face watch?
I’m not sure I’m reading you correctly. Would you like to install additional watch faces on your watch? You don’t need WiiWatch for this. For example, you can connect your watch to a PC using the cable. Then you can download a watch face in Clockskin format to the PC. Here in the forum you will find thousands. Unzip the ZIP file and move the unzipped folder directly to the “Clockskins” folder on your watch.
Thank you for your time!
You are welcome.
By the way, do you know an application to mirror your smartwatch screen on your PC?
Scrcpy or Vysor, for example
TOP. thanks
Google fit works on lem 14?
I ran it on mine.
Mine don t sync… What i m doing wron!
Have you read this to enable it to run in the background
I set it up to run in background so the firmware wouldnt kill it to save baterry.
