Play Store download loop in V03: https://we.tl/t-3qUfpwg1cL
So, this only happens after you install something from the playstore?
@none here V03 Boot loop while using the builtin “Browser” app: https://we.tl/t-YQXHFXLMLP
On->Off->On cycle.
But I can easily tell V03 is 1000 times stable than before. Reboot/loop is rare and watch able to tolerate much more load for long time. I could even stayed in a Google Meeting for 5 minutes until “Google Meet” app crashes.
There is no need for so many logfiles, like Pablo11 said the initial problem is the same.
We just need to figure out at which point the corruption starts.
You need to tell me if this happens right from the start with a clean firmware flash or only after you setup your google account and downloaded something from the play store.
The browser app was crashing and a boot loop happened right after flashing before doing anything.
Then this might be a hardware issue, there was a case when the corruption only started after using the play store which indicates a problem with the google framework implementation.
Should I wait for the watch to boot on its own after the flasher tells it is done? This does not happen and the watch stays off. I am powering on the watch manually after some time.
Manually powering the watch is correct, it doesn’t automatically boot after flash.
Sending the watch for replacement. Thanks for your time guys.
You did the right thing.
Looks indeed like a bad chip.
If you have any problems let me know
Thanks for your support Pablo and everyone involved. Next Lem 12 PRO is on the way.
Good news
