Hello everyone,i received the Lem 10 five days ago and the battery life it’s really poor: barely 7 hours only with mobile data on and screen brightness at minum level, no GPS no bluetooth no wifi on. I have disabled Google Sync, received just some whatsapp…no calling, no vibration. And about the touch screen : on the bottom it’s really difficult to type or tap icons and so on. I tried to connect the watch via USB to transfer files…no connection…it failed. Any tips how to improve or solve this issues? thx for support.
have you activated the USB file transfer in the USB settings ?
No…I will do…my bad, on the Lem T didn’t do that and it worked. Thx a lot!
In settings-connection the USB option it’s not available:frowning:
The issue could be whatsapp running in background . Make sure its disabled in battery saver and let me know what battery life is like . I have a Lem10 and battery is superb . Thanks
Is it charging okay with cable ?
In order to receive notifications from WhatsApp I have to disable it in the battery saver list.
Yes it is… although need to check carefully if it’s plugged good… that’s another little issue. Thanks.
I appreciate that . But it has been noted that it is a huge battery killer ( or was ? ) . Just trying to get to the bottom of your battery problem .
Thanks a lot!! My husband “stole” my Lem T and gave me the 10…ppppfffff!
so… this discussion ended on “the steal story”… sombody please share the solution for battery life too.
Are you just wanting general battery saving tips ?
not only saving battery option but also some other options what I want to keep active. In default settings for battery… Screen turn off in 15 sec… when screen turns off… only pedometer remains on… and everything else turns off. So what I do…
- I keep whatsapp (not in battery saving mode), to keep it ON
- Google maps requires (always) to enable “the most battery consuming option” GPS+wifi+bluetooth+mobileDate (which i don’t want but this is a compulsion).
- Also I want to keep active google maps so my location could be tracked (for my kid actually) or suggest me some different app for map with sharing location to parents … which is safe too according to their privacy policy.
- If screen is ON with MAP navigation on 3G or 4G (this watch becomes soooooper hot)
These three things i need. whatsapp + location services + (Alternative to Google Map but good location reporting to parents.)
With all of these… I think battery doesn’t last for more then 30~ 40 minutes…
Thank you
I think you may need to be a bit more realistic to what these watches can do with the size of battery they have . Running apps with screen - wifi - 4g - gps all on at the same time will kill all the watch quickly especially if tracking your children . Probably not relevant but standard battery saving tips are
Pedometer off
Wifi and gps only on when required
Google sync off
Raise off
Apps in battery and data saver - on
Screen timeout - 5 seconds
Most users come up with there own combination after testing whats best for them.
Sorry but i have not tested any tracking apps to suggest .
thanks… so… with above combination we got only … “Watch Face”.
Did you forget phone notification from WiiWatch or we can use that at least? … I will have to buy something different for child then.
Personally i would use watchdroid . Much better that wiiwatch 2
Does that work with IPHONE
No, watchdroid doesn’t work on IOS.
I wasted 130usd for a 20$ thing!
I accidentally ran my Lem 10 completely dry and it shut down on its own. Thought this would be a good time to check the battery capacity with my inline V/A meter. So when it was completely charged to 100% it showed the battery accepted 780mah of power.
