KYR Watchfaces: KYR Stride
Available in my blog.
Watchface Features: Analog time (hour, minutes and seconds hands). Digital time (hour and minutes). Weekay. Day. Month. Weather. Temperature. Moonphase. Battery percent.
Tap options for compatible watches: Tap in the day or in the weekday dial to open the Calendar. Tap in the battery icon to open the Battery Options. Tap in the wearther icon to open the Weather app.
Inspired by a watchface I saw in a watch in Aliexpress and I wanted to do a similar design, this watchface combines analog hands and digital time in a modern design. With a grid pattern in the dial that includes a dark metallic star in the center of the watchface and two colored areas with different info displayed in classic digits that reminds the old retro digital watches, complemented with a battery percent in the left side that acts as a subdial, this is a watchface you can use in your smartwatch to catch anybody’s attention.
If you’re looking for a modern look that brings you the digital digits you loved so much in the past as well as analog hands, this is definitely a watchface you must not miss!
IMPORTANT NOTE: The tap options in the version for Android 10 ONLY works with the stock firmware, and NOT in the different beta “International FAW firmwares” developed by Full Android Watch and Wiiteer, because some of the apps used changed from one version to another, and others disappeared. Some of them may work, or not, in those firmwares. Keep this in mind if you’re using any of those firmware versions.
Tap Options Video Preview:
Damn men, this is really one of the goods!!!
Thanks!! I’ll try it on my LEMP (A9.1)
Pd: I’m going to try to change the default calendar app in order to open my new ‘Good Calendar’ app I recently installed last week.
Thank you, StringRay!!!
Feel free to modify it to use your app. I make them to be compatible with the OS of the watches I can test it on (Android 10 in my Kospet Prime 2, and Android 7.1.1 in the Kospet Prime SE of my best friend). But of course, if you have the knowledge to modify those “array 100”, you can do it.
Looks great there!
Damn men… What watch is it?
