Available in my blog.
Watchface Features: Rotating colorful background. Analog time (hour, minutes and seconds hands). Weekday. Day. Month. Weather. Temperature. Battery percent. Steps.
Tap options for compatible watches: Tap in the day to open the Calendar. Tap in the weather icon to open the Weather app. Tap in the battery percent icon to open the Battery Options. Tap in the steps icon to open the Sports and Fitness app.
New colorful watchface with a cool effect to make sure the colors aren’t always static. This dial features a spinning pinwheel that continuously rotates, so it will never stay in the same position. Also, the color of the hour markers matches the nearest color, so this markers are also continuously changing. The modern font used for the hour numbers and the info completes this cool design that will leave no one indifferent.
If you’re looking for a colorful and stylish watchface to give a cool look to your wrist, you must not miss this one!
IMPORTANT NOTE: The tap options in the version for Android 10 ONLY works with the stock firmware, and NOT in the different beta “International FAW firmwares” developed by Full Android Watch and Wiiteer, because some of the apps used changed from one version to another, and others disappeared. Some of them may work, or not, in those firmwares. Keep this in mind if you’re using any of those firmware versions.
Video Preview:
