KW99 Weather inquiry
KW99  Note 8
I am using the latest Universal Launcher and it shows the weather okay but when I want it on my new face, it shows an incorrect temperature.
I am using the fantastic Watch Face Designer 9 and 10.
How can I correct this please?
oz
Jan 5, 2018 0:44:55 GMT 1 ozstar said:
ricktop
do you mean that the app weather is updated but not on the face?
Yes as soon as it is connected to the Note 8, it updates the weather (as in the pic) on the watch and on the next screen, for the next 6/7 days.
It does not do this on the watch face as you can see.
The actual temp sometimes shows 0% then 9% within a few secs of each other when the real temp is 25%
I have just had a thought!
The watch face shows…
6C and Thunder
The correct in the watch Weather app is
26c Full sun
As we here in Australia are in summer and the face is showing what would be a winter result… could it be it is getting it’s info for the face from the winter zones (Northern Hemisphere) ?
How can I check this?
KW99  Note 8
oz
I need to see your watchface in Clockskinmaker, to good coded or not. Maybe face coding issue. When not, than you need to see in Universal launcher, that weather setting correct or not. Not the default launcher setting.
Thank you for you offer of help.
I see that the watch says it is connected to Accuweather via the Univ Launcher and it does show the correct temp, Rain chance for now and the next 5 days.
Unfortunately the watch face does not. At the moment on the phone and in the Univ launcher Weather app, it is 45 C here and the watch face says 7c with showers. Big difference !
mpmf the designer of the fabulous Watch Face Designer script, confirms he just tells it where to show the info.
So it sounds like it is getting the wrong info for some reason.
Is there somewhere in the watch that sets a location, in case it is set to a Norther Hemisphere, like where the watch came from?
I appreciate the help as I really want it to work properly.
oz
PS Hpw would you like me to show you my clockface design?
oz
Just upload the face somwhere.. e.g. your google drive, and click to share, copy the link and paste here..
oz
You need to set your location in the launcher, go on the skin prefs setting screen as showed in the tutorial.
