KW99 In Abour Wireless Upgrade - Test Version
I have just noticed that in the About/Wireless Upgrade screen I see it is a Test Version.
No matter how many times I press the arrow, I still get the same result.
‘invalid data from network’
Why is this please?
oz
I see that  the Build is KW99-CS1-B-20171013   AND KERNEL   3.10.72    aND 5.1
Feb 2, 2018 1:40:02 GMT 1 ozstar said:
the latest version is the bt calls app, do'nt worry about the test version.
Okay thanks…
The ‘BT calls’ app works well so I guess I’m up to date. As long as the Note 8 is paired and connected I can call out from the watch.
I still can’t get wiiwatch to work with my Note 8. It refuses to BT connect.
I am also using the Univ Launcher again now. I downloaded it from PlayStore now so I guess it is the latest.
Feb 2, 2018 10:12:41 GMT 1 ozstar said:
Okay thanks.. The 'BT calls' app works well so I guess I'm up to date. As long as the Note 8 is paired and connected I can call out from the watch. I still can't get wiiwatch to work with my Note 8. It refuses to BT connect. I am also using the Univ Launcher again now. I downloaded it from PlayStore now so I guess it is the latest.
it does'nt work with the note8? which andorid do you have on your phone? if it is the latest so i think the wiiwatch is'nt updated to work yet with it but not sure.
Okay thanks…
it does’nt work with the note8? which andorid do you have on your phone? if it is the latest so i think the wiiwatch is’nt updated to work yet with it but not sure.
Looks 7.1.1
Looks 7.1.1
not android 8?
No it says Android 7.1.1
Samsung Experience version 8.5
Baseband N950FXXU2BQKG
It says latest check was Feb 3. Is this not the latest ?
this version i have on my note5 and wiiwatch works fine, have you checked if the app is up to date on the phone?
Yes the phone ‘wii’ says it is up to date.
So I can be sure I am doing it correctly, is there a video which runs through the wii connection?
I am definitely BT paired with the note 8 according to the watch, however can’t see where to confirm it is actually 'connected.
The phone wii tells me the watch BT needs to be connected.
A little confusing unless I can get a flow chart type of overview with all steps. Thank you for your time too BTW.
try to unpair and pair them again and try from the wiiwatch settings to connect them again.
