KW99 has gone dead
One of our KW99s is now dead as a doorstop.
It was around 10% battery so I charged it but since taking it off the charger, it is dead.  No response whatso ever.
The charger works cause I used it with our other KW99.
It was not dropped, watered etc… just normal wear.
Any ideas please?
Only had it just over a month.
oz
Jan 21, 2018 5:25:29 GMT 1 ozstar said:
try and see if you can flash it with it's firmware, but first have you opened it and seen that all connected? battery?
Thank you for your help… How would I flash it if it is dead and there is no usb port ?
It still shows as paired in the Note 5 but will not connect. It says, ‘Connect’ in 99 but can’t as it is dead.
I will open carefully and see if battery is still connected but don’t have a multi tester here with me to check it if it alive and well.
Is it replaceable if it is flat?
Is there anything I should look for or be careful of when I open it?
oz
Probably need to disconnect the battery and reconnect after. Sometime it helps to make it charge again.
Okay. Thank you.
As soon as I get the small screwdriver I will give it a go.
Hopefully this will fix it. I will report back what happens.
I do appreciate both your help
oz
Jan 21, 2018 7:30:29 GMT 1 ozstar said:
you do'nt need it on to flash it:) but first check if battery is connected or not check all cables if they are connected.
Okay, I have the back off but not sure where the battery is.
Is there a few pics of the inside somewhere so I can be sure I am at the right place?
Just a quick update to this…
Is there an image somewhere which will show me where the battery is on my KW99?
Is it the same as the KW98?
I need to fix this.
Jan 27, 2018 0:31:41 GMT 1 ozstar said:
Just a quick update to this..
I need to fix this.
yes, as the kw98
I need to fix this.
Don’t know if you found this so I am sending it your way. It is a screen shot of component location in the KW98, from YouTube. While you are in there check for corrosion, it has shown up on other watches and could cause battery problems.
Interestingly here is the inside shot of the LES 1 and they are nearly identical.
I need to fix this.
Many thanks for this. I missed it on YouTube. When I open the back my 99 it has an aluminum plate over most of what we see here. I guess I have to get that off first. Really appreciate your help. oz
I need to fix this.
yes, as the kw98
Thanks Soniasophie
As I purchased insurance on the watches when I bought them, I have decided to return the watch that is dead.
I do not want to find any warranty by mess I with it inside and then it still not working.
Well the insurance company, offered my the full price I paid for the watch however it was in the form of a Gift Voucher in 1 of 2 well know stores. These stores only sell the more expensive watches so it is really no good for me.
I want to get another KW99 or a smaller watch (it is for my wife) about the same price.
I bought the watches on Ebay so have requested return or swap there now.
Any suggestions for a smaller watch like the 99 and around the same price?
oz
After conferring with them, I must say the Ebay seller, was honorable by offering a new watch. It is good to know that there are still those people and companies who put integrity above profit.
oz
it is better to wait for new upgraded kingwear watches and most likely the microwear watches also.
