Hi, with this upgrade for KW98 there is a small heart measurement problem. Can you check it out?
The problem has been found.
The heart rate sensor does not work and gives a bug.
I checked them with another and everything worked.
Perhaps others have the same hardware problem.
From moisture (sweat) of the hand, the sensor is oxidized and stops working.
Excuse me for losing your time.
Nov 16, 2017 1:11:59 GMT 1 holandeca11 said:
The problem has been found. The heart rate sensor does not work and gives a bug. I checked them with another and everything worked. Perhaps others have the same hardware problem. From moisture (sweat) of the hand, the sensor is oxidized and stops working. Excuse me for losing your time.
did you reset the watch to see if it fix it?
It's working on my KW98.. As you say, it could be a dirty sensor connection. I'll check it again.
Yes, I tried.
The problem is in the sensor. I tried it on another watch and it does not work either.
I have tested on mine - flashed twice and it is working ok.
I will try it on my KW99 and see if that also works
By the way - your KW98 - does it have 4gb storage or 8gb?
Tested on KW99 as well - same watch really
Works fine.
Did you use the firmware upgrade option in SP Tools ?
The new firmware version works perfectly on KW88, KW98 and KW99.
I tried it at all, as I use it firmware upgrade option in flash tool.
Just on my KW98 (8GB storage) the sensor does not work.
When I changed it with another sensor, everything worked.
Thanks for your time.
Great work, by the way.
Hi ,
i installed the firmware (KW98_V1.3_B_20171111) to my kw98 but i’m having issue with bluetooth. It’s turning off and on constantly. any help?
Jan 10, 2018 15:34:53 GMT 1 cemgil said:
Hi , i installed the firmware (KW98_V1.3_B_20171111) to my kw98 but i'm having issue with bluetooth. It's turning off and on constantly. any help?
it is just weird i flashed my kw99 with bt calls app firmware and i do'nt have any bt issues.
Hi ,
it is just weird i flashed my kw99 with bt calls app firmware and i do’nt have any bt issues.
i installed stock rom now but bt is still turning off and on.
Jan 10, 2018 18:29:25 GMT 1 cemgil said:
have you made sure to choose upgrade instead of download only?
I installed with format+download now i installed 20170628 firmware and switch to no backround procces limit in dev. Options i tried today its working without any issue. Can i have anyway to install latest build?
Jan 11, 2018 20:42:14 GMT 1 cemgil said:Jan 11, 2018 17:42:58 GMT 1 soniasophie9697 said:
ok, not good most likely you’ve lost your imei of the watch…you have to flash the stock firmware NOT any update or new firmware first the stock one after that you can install the firmware that has the new bt calls app BUT make sure you choose upgrade and nothing else just remember all this will not restore your imei and you can’t ask on the forum how to recover it, sorry it is just illegal in most countries to do so.
thank you for your interest. imei is not important for me, i ll not use simcard with watch. Now, i can install latest build (20171111) with sp flash tool and select firmware upgrade option, can i? is it neccesary uncheck preloader option?
thank you again
Jan 12, 2018 11:23:17 GMT 1 cemgil said:
thank you for your interest. imei is not important for me, i ll not use simcard with watch. Now, i can install latest build (20171111) with sp flash tool and select firmware upgrade option, can i? is it neccesary uncheck preloader option?thank you again
no,
it is safer if you first flash it with it’s stock firmware and just then with the bt call app firmware. and yes in all time preloader should be marked.
i installed the firmware using firmware update option but i have bt problem still. I’m using watchdroid for notifications because wiiwatch doesnt connect ( htc 10 ).
Jan 12, 2018 15:51:20 GMT 1 cemgil said:
i installed the firmware using firmware update option but i have bt problem still. I'm using watchdroid for notifications because wiiwatch doesnt connect ( htc 10 ).
what? which firmware did you use? what did you do? step by step...i have no disconnections and i use wiiwatch and it works fine with bt calls.
what? which firmware did you use? what did you do? step by step…i have no disconnections and i use wiiwatch and it works fine with bt calls.
i installed firmware that 20171111 for kw98 via sp flash tool v5.172. i selected firmware update and flashed. is there any wrong?
Works fine.
Hi can we flash Lemfo LEF1 firmware on my KW98?
