Can someone please provide a detailed instruction how we can set proper watchface to the KW88 using Nova launcher and Zooper Pro? Thanks. I already have all the apps required and transferred the .zw file to the template folder but I’m having a hard time making it look perfect.
Yeah hopefully we can consolidate everything in this thread. I’m also struggling to find clear instructions that’s why I decided to post another thread.
@Kenneth_Tan Hi, yes I was able to load the Rio watchface, but setting it fullscreen like what you di to yours was next to impossible for me. I can’t get of the circle at the bottom and the face itslef doesn’t reach the edges.
GOTO Novalauncher/settings/Desktop/advanced. Enable widget overlap.
Try if that makes a difference.
Then goto scale in the widget settings page and scale it to the max possible.
I found it to be different on different watches.
Also because it’s scaling and not pixel relative it sometimes screws up the position of some watchface elements.
A god examole of that are the led bars on the V22 watchface. They tend to shift on scaling the entire face.
@George_Zervas . If it’s a touch problem for you not able to reach the upper screen area. I’d suggest you installing Teamviewer Host on the watch and controlling it through your or mac. Then you’ll see the full square desktop and you can reach all corners
One important also
Is how hide dock
If you use nova pro no problem just enable auto hide from settings
If you use free nova
Open zooper
Configure widget/act on tap/
Swipe right
Nova action and nova menu appear
Hide show dock.
Thats it and disable page indicator for full screen watch
I’m backreading a bit regarding zooper, so there’s really now way to maximize it to the edges of the round screen? there’s really going to be that gap?
Exactly, there is no way to maximize a widget to the edges of the round screen. The only way that I can think of to have a clock fully maximized is using a live wallpaper clock and I am not able still to find one that really deserves my KW88
