KW88 spare antenna and cables ?
Hello,
As my watch was keeping loosing connection with phone at about 30 cm and got very bad wifi signal i have opened it , the patch antenna of the wristband was torn and the wires broken , i have fixed it the best as i can but the better will be to change them.
Do you know where to buy them? I have searched on aliexpress but i’m not sure about the cables and i can’t find a good wifi/gps antenna from phone.
Nov 25, 2017 19:16:32 GMT 1 theduke said:
Hello, As my watch was keeping loosing connection with phone at about 30 cm and got very bad wifi signal i have opened it , the patch antenna of the wristband was torn and the wires broken , i have fixed it the best as i can but the better will be to change them. Do you know where to buy them? I have searched on aliexpress but i'm not sure about the cables and i can't find a good wifi/gps antenna from phone. Thanks
the only place you can try is alibaba, but do'nt think it will be easy to find.
Thanks,
I have ordered a wifi/bt antenna for iphone 5, it’s a flex and small one, i think it will fit inside the wristband , but the connector don’t seem the same but a cut and little solder should do the work. I will loose the gps antenna (but as she was totaly torn not a great loss).
For 1.5€ i think it worth to give a shot.(it could have been lot of cheaper but it sent localy so i wont wait 1 month to get it)
Hello,
I have got the iphone antenna and it’s a perfect fit for the connector. I got a good wifi/bt signal now .
The only con is the thickness of this wire i hope it wont break (i have put a good layer of superglue before close the wristband ).
