Somebody tried the recovery console on this watch? Can i use a .zip file to update firmware? e.g. custom firmware which made by android kitchen?
Stock recovery can’t install custom zip packages.
TWRP recovery for KW88 is almost ready but still has an issue to fix; the display is upside down.
I’m working to fix this issue.
Sept 26, 2016 8:22:11 GMT 1 Ciro Danise said:
Stock recovery can't install custom zip packages. TWRP recovery for KW88 is almost ready but still has an issue to fix; the display is upside down. I'm working to fix this issue.
Today i browsing the build.prop and i found this: ro.sf.hwrotation=180 I think think the problem is the rotation,because the TWRP not rotate.
Oct 21, 2016 16:14:05 GMT 1 janek said:Sept 26, 2016 8:22:11 GMT 1 Ciro Danise said:
Already verified. Unfortunately that is not the issue.
