Hi guys,
Tired of waiting for KW68 or KW99 Pro.
For general use, do you guys recommend KW88 pro?
Hi guys,
Or if possible link to the sale thread of KW99 pro or KW68
the only places i’ve seen these two are on alibaba no where else just weird that the kw88 pro is quite a while in stores and they are’nt.
BTW - do you recommend KW88PRO?
Features wise and battery backup?
Deepak, not sure as we do’nt have the watches but they should be way better than the kw99 and kw88 cos it has only 512mb of ram and andorid 5.1 which is battery consumer and the new upgraded version has 1gb ram and android 7.1 which is way better in system management and battery usage. these two specs are important for battery life.
Sept 23, 2018 15:31:59 GMT 1 soniasophie9697 said:Deepak, not sure as we do’nt have the watches but they should be way better than the kw99 and kw88 cos it has only 512mb of ram and andorid 5.1 which is battery consumer and the new upgraded version has 1gb ram and android 7.1 which is way better in system management and battery usage. these two specs are important for battery life.
One last query, if we compare this KW88 Pro with KW99 Pro… Any area where KW88 pro falls behind?
Sept 23, 2018 17:13:19 GMT 1 soniasophie9697 said:Deepak
no, the only differences is the look but all is the same:)
Should I go with this or wait for KW68?
IP68 is not a big thing for me…
it is better to wait, i did’nt have any problems with my kw99 even though it is’nt ipxx but still works great.
Sept 23, 2018 20:12:57 GMT 1 soniasophie9697 said:Deepak
You mean wait for KW68 or KW99 PRO?
Any specific reason?
no, the truth i like way better the look of the kw88 pro over the kw68 but i also like the look of the kw99 pro so it is better to wait and see which looks better:) cos all specs are the same just the look is different:)
Sept 24, 2018 6:54:34 GMT 1 soniasophie9697 said:Deepak
So that means if I am already preferring the shape of KW88 PRO, I should go for it?
Sept 24, 2018 14:49:52 GMT 1 soniasophie9697 said:Deepak
yep:) i actually like it more than the kw68 the only pros for the kw68 is ip68.
OK thanks Sonia…
Will hopefully go with KW88 PRO
One last thing… Please guide from where should / can I buy it?
@deepack
i only buy from aliexpress cos it is more reliable and in case you do’nt get it you get full refund.
dont buy kw88 pro its docent support Bluetooth calling still im facing that issue
how to install google assistant in kw88 pro
I think you can use assistant if you have the Google app installed as a system app
Its not a issue . No android 7.1.1 support bluetooth calling
