Received my KW88 pro today. Was working OK all day. When I got home from work tonught I was having a proper look at it and was trying to log into my Google account. Then the phone just froze.
I can still display the time but it looks like the touch screen option is gone. I can’t touch anything. When u hold down the power button I get the ‘turn off, restart, last app’ etc…but I can’t select anything
When I power down the phone completely (hold power button for about 10 secs) it re-starts but goes to the same thing again. I’m stuck in a rut.
Kingwear have'nt released yet the watch for sale i do'nt understand why seller sells most likely not the finished product. let me check what can be done, most likely you'll have to flash the watch.
It is on sale.
I will try to get the firmware for you
Can you tell us if your pc recognises the watch?
I mean can you hear a noise when you connect to your PC?
mines has exactly same problem i managed to reflash firmware it loaded up fine and when powered up watch it came up language confirm but screen still wont respond to touch
Which firmware did you use ?
There are several screen types and if you have the wrong one then touch will not work.
Do you know which firmware you had before you flashed?
