kw88 pro battery life
hiii ,i want to increase battery life of kw88 pro so that it can last for a day ,right now i have to charge my watch twice a day than it lasts for 8 hour ,m not using any sim, not using WiFi just a bluetooth connectivity
Then brightness and wrist gesture are the main options to play with. But it doesn’t look like a normal battery life…
the app greenify helped me, try it!!
do i need a root to use greenify app ,and what should be the normal battery life if m using only bluetooth and wrist gesture function
I use hibernation manager, similar to Greenify   without root and it allows you to automatically turn off selected apps while the watch is asleep. The wrist gesture function is a big battery consumer and in my opinion is rarely actually needed. On either my I4Air or Lem 7 I keep BT and the pedometer on during the day with WatchDroid running about 16 hours a day. I keep wi-fi and other connectivity's  off unless I need them and average about 24 to 30+ hours per charge. How you use your watch determines battery life. Smart battery management is essential  if you want to get a good days use from your limited battery available.
thanks captjon for the suggestions
