Hi all. The KingWear OTA method is a little different from most.
They are releasing different OTAs for different original firmware levels.
So if you are on the 21060801 FW you can download the new OTA already.
If you are on the 20160730 FW you will have to wait a while.
Please remember - if you have root you cannot take the OTA unless you go back to full stock FW.
Also remember that it may not be worth you doing this if your watch is perfectly fine at the moment. For instance - this latest release only changes CPU settings to reduce random reboots - that’s it.
