Need to know exactly what you did and which options you selected in the SP Flashtool
Download mode with pre loader:sweat:
Jan 29, 2017 0:16:17 GMT 1 nusa1979 said:
Download mode with pre loader😓😓😓
Which firmware ? Pre-loader flash is a very bad move !!
I have testet with all firmwares but every time same problem. Every thing working fine accept update…( mobile param is invalid ) shows up.
As I said, which one did you flash before you saw this problem?
Latest 20161215… ![]()
I see now… i have lost my Imei and serial ![]()
Hi yes i did the same thing and have the same problem is there a way to fix this problem?
yes, flash the stock rom NOT an update and make sure to remove the v from the preloader. about the imei also yes but can't be discussed here:) sorry.
yes, flash the stock rom NOT an update and make sure to remove the v from the preloader. about the imei also yes but can’t be discussed here:) sorry.
Ok thank you
