szega
November 17, 2018, 3:59pm
Does anyone know where I can disable heart rate function altogether?
I couldn’t find an option for it but noticed that time after time the little green light at the bottom of the watch does come on and I want to disable it to preserve more battery.
Nov 17, 2018 15:59:19 GMT 1 szega said:that does not suppose to happen, which apps do you use?
szega
November 17, 2018, 5:11pm
3
It wasn’t through an app when I noticed this.
It happened when I had my watch on the shelf then I picked it up to put it on my wrist.
When I lifted it off from the shelf the green light came on making me wonder why that is happening and thought there might be a way to turn it off.
Nov 17, 2018 17:11:25 GMT 1 szega said:
you need to reset the watch and see if it still happening and notify here and we'll see if it can be fixed by firmware update.
Nov 17, 2018 21:05:07 GMT 1 szega said: Reset solved it.
Thanks for your help
reset do you mean you did factory reset? that means an app caused it.
szega
November 18, 2018, 11:03am
7
Yes, I did a full factory reset.
Must have been one of these dimming apps that caused the trouble as those were the latest that I installed.
