KW88 - get to the usb mass storage connection options
Hi everybody,
I’d like to know how to get to the usb mass storage connection options in settings. I’m looking for it, but haven’t found.
Sometimes when I connect the watch to the PC, it’s not recognized, so I can’t get to the internal memory. Gain access to this options will help, I think.
Ocassionatly I get a notification in the watch that let me into this settings, but not always, that’s why I want to know the way to get there.
Thanks in advance!
Nov 5, 2017 4:51:48 GMT 1 tcc said:
have you tried to see if the cable is the problem? which window do you use?
Don’t think so, the problem with the cable it’s the s**t magnetic system, continuosly unplagging with any little movement. God, I miss a standard usb plug.
Anyway, what I don’t understand is how with a complete Android version inside, there are a lot of settings sections not available to the user.
so true , i also think the old usb connection was better than the magnetic one, try cleaning it with alcohol i do that and i get instant connection sometimes the dots need to be cleaned especially as i workout alot with the watch. about the settings true they stripped it from many important stuff that we use and need, have you tried with google gesture to locate what you need?
Hi everybody,
Thanks in advance!
Install “Settings Search” from the Playstore.
