KW88 can't upgrade firmware.
Hi and thanks in advance!
I’ve followed the steps given in this video:
The problem is that when I start SPFT and connect my turned off watch, it is not recognized by the program.
I’ve installed VCOM drivers, USB MTP drivers but can’t get connection.
Any idea?.
Thanks!
Dec 4, 2017 1:10:23 GMT 1 tcc said:
most likely the problem is with the cable, i had a similar problem and the only way i could flash is hold the watch with cable together along the process.
No way, even changing cable and holding it. I’ve read that maybe using XP can success, but not sure. Any other idea?.
Thanks in advance!
Thanks in advance!
can you try with more updated win?
Thanks in advance!
My first two tries were in two different W10, now I’ve tried in WXP but still can’t get connection.
the only thing that can be the problem for not recogonized by the pc if drivers installed and usb mtp also is the cable itself, try cleaning the dots on the watch with little alcohol and see if it helps.
