kw88 camera not open after flash new frimware.
hi all i change frimware all ok but camera not open. error camera use other app or other app use flash… etc
maybe need driver or offical app. someone still use camera after update frimware?
Dec 19, 2017 19:24:08 GMT 1 seawave said:
hi all i change frimware all ok but camera not open. error camera use other app or other app use flash... etc maybe need driver or offical app. someone still use camera after update frimware?
did you use upgrade when you flashed the watch?
no just download
Dec 19, 2017 21:59:45 GMT 1 seawave said:
no just download
did you install the last firmware that include the bt call app?
now my watch died. not turn on and not open usb port and accept firmware update. how i fix this?
to flash it you do'nt need it on, but you need the pc to recognize the watch,did you follow what i wrote you to do?
you have to hold the cable tied to the watch when you connect to pc and also press the shut down button on the watch till you see connection with sp f.tool.
