Hi All,
The battery in my KW88 has puffed up and no longer holds a charge or even fits in the case properly.
Does anyone know where i can find a replacement battery for this?
Thanks in advance.
BoX
Hi All,
Thanks in advance.
BoX
Jan 31, 2017 20:02:21 GMT 1 box said:
Hi All,The battery in my KW88 has puffed up and no longer holds a charge or even fits in the case properly.
Thanks in advance.
BoX
Thank you, I will try them.
BoX
How do you replace it? Because connectors are different.
Feb 1, 2017 14:08:51 GMT 1 cabrerachaparro said:
Hi,How do you replace it? Because connectors are different.
The size of the battery should not exceed (5.0mmX27mmX28mm). Here’s an example:3.7V 502530 400 mah lithium-ion polymer battery quality goods quality of CE FCC ROHS certification authority
Did you try replacing the battery?
I too am facing issues with my battery. It suddenly dies from 40 - 50 % charge sometimes even more. I will have to replace the battery. Please help me with where I can buy them. If a genetic 350 mah polymer battery would work ,what dimensions would fit to kw88.?
Try this seller
original kw88 smartwatch
s.aliexpress.com/26NfMnEj
Hello, does anyone know where a replacement battery ith the proper connector might be purchased for a reasonable price? (I am in Australia)
Also without pulling mine apart before getting a replacement, what is the actual maximum size that would fit if I have to look for a generic battery.
Please help me as my watch lasts a very short time now.
Terry
I found this one:-https://m.de.aliexpress.com/item/4001045272418.html
Thanks G1NT0N1C,
I checked it out, and it looks good, though they do claim 550mAh.
Which seems to good to be true, compared to other similar sized batteries.
Has anyone out there fitted one?
They are also quite expensive, so I don’t wish to buy one till I am sure.
Any other comments would be great.
Many Thanks
Terry
I have already taken care of using Google for you. That’s all I can do. And if it is the only battery you can buy, it is also the cheapest battery…
