Sept 17, 2016 19:14:18 GMT 1hranac3 said: Looks great!? Not as ssharp as I'd like but that's just me.ill definitely be donating to you for this and any others you make keep it up!!!
Thank you... the original watchskin is larger and has a numbered bezel... but a bezel on the skin and on the KW88 just looked too busy... I removed the bezel and scaled the image up - there was a loss in definition
Awe that makes sense hope you got my donation. And I’m looking forward to your next one I’d like to get in on coding these as well or if you need a tester let me know
What is the background file type that is supported for the apk
The apk watchskins use png images… current we’re only able to use a dial/face and three hands h/m/s… a date can be added and uses the stock ttf (Robotica/Roboto?)
