KW 88 screen turned up to down
It was this forum but it was the older KW88.
We made it work with a custom made firmware that did not come from KingWear.
It was a cooperation between me and the firmware team that produce the firmware for KingWear - and many other brands.
Anyway, I am asking them to see if we can produce another custom version for this model with the new screen.
If they are too busy I will see if I can get the time to do it.
Iโ€™ll let you know how it goes.
Thanks in advance, Iโ€™m looking forward to that.
Can someone please help me to, i have downloaded the software KW88_CS1_OHH_B_GSM_PHT_20180821 but i think i also need the preloader file
What is the ram and storage size of your watch?
its the same 512 4gb have the same problem also
pablo11 I got this one for U
bigpappa
Link for the preloader for that watch model is on page 10 of this tread (10th post on 10th page). Remember to remove checksum files after changing the preloader in the firmware folder.
May i say thanx you to you all it worked u can use my watch again after 4 months
Oct 21, 2018 6:45:22 GMT 1 elobayor said:pablo11 I got this one for U bigpappa Link for the preloader for that watch model is on page 10 of this tread (10th post on 10th page). Remember to remove checksum files after changing the preloader in the firmware folder.
Thanks for the support ๐Ÿ‘๐Ÿ‘ I have been unwell and so community spirit and support is very much appreciated.
No probs
Any news about the fw allowing bluetooth calling?
Oct 25, 2018 17:34:37 GMT 1 elobayor said:
No probs Any news about the fw allowing bluetooth calling?
No, if that had happened I would make a forum wide announcement ๐Ÿ˜
Oct 15, 2018 6:55:36 GMT 1 elobayor said:
And now we are int he point where problems were. THis time I could load fw, flashing went well and the screen is in right orientation. THANK YOU MATE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! YOU'RE BRILLIANT
Ha ha, I am very happy to hear that ๐Ÿ˜ Thanks for your patience. Cheers Pablo
Hi, I need to know what are the steps to follow to solve this problem ...
KW88 screen down
Video problem โ†’
pleaseee help meee!!
thanks!!!
msa239
go through this thread the answer is in it.
Oct 14, 2018 2:41:36 GMT RASC Moderators said:
Oct 13, 2018 19:28:48 GMT elobayor said:
How to check if sp f.tool detects the watch?
Ok, replace the pre-loader file in the firmware pack I sent you last N With the attached file. Unzip and copy into FW folder and replace the existing one....
Flash again. As I said - if flash tool does not recognise the watch try pressing power button while flashing or disconnect and re-connect the battery.
Pablo11
Hello,  I have two KW88- one OHH and second NHH. I flash this firmware KW88 OHH. Firmware great. Many thanks. All work!!! And now I d`like flash KW88 NHH same firmware. Maybe you can help me?
Hi there.
My KW88 was functioning OK with KW88-CS1-B-GSM-PHT-20171111 but I tryed to flash KW88_CS1_OHH_B_GSM_PHT_20180821 to see if there was some improvements, specially the battery lasting time.
Tryed first with Download only (not really, had to do Format + Download because of error) and then with Firmware upgrade.
Both flash OK but in both the clock starts but screen remains black (I hear the sound of clock starting).
Is this normal behaviou, do you have some idea how to recover? Firmware KW88_CS1_OHH_B_GSM_PHT_20180821 is just to correct the inverted screen problem? Is has no other improvements?
I can flash back to KW88-CS1-B-GSM-PHT-20171111 and clock starts and work fine.
Thanks in advance for all enlightment you could offer.
i have the same problem, you send file to for me?
Please firmware kw88
Please senythe zip file to daffatool7@gmail.com
Please open the activaton pleaseโ€ฆ
