Sensor works so bad for me for example I can’t use search tool in youtube I want to press on icon opens account page instead of search bar
Question to you guys: Are any way to change sensivity???
Are you saying the screen is not responding correctly ? If so i would factory reset the watch .
The sensitivity cannot be altered . Also the watch performs better on the wrist ( not holding in hand as a pocket watch )
Also dont forget if you hold and press the top button you can switch from full screen to square screen to access corners easier
The Prime 2’s touch sensor requires skin contact on the underside of the watch. I either put a finger on the back or I wear the watch on my arm. I have also found that the prime 2’s touch sensor works better when the screensaver is removed.
