Guys I can’t find my Kospet prime 2 charger
Right now I have Domino dm 368 is it ok if I chatge with that?once I charged charging time was pretty long
Since not all charging cables are the same there is no way to know for sure unless you can match the polarities of your watch and that cable. If it is wrong you could fry your battery.
The polarity of the prime 2 charging cable is different from any other cable I know. NEVER use another cable!!!
Are you sure?
100%. I checked about 20 cables a few days ago.
Thnx bro a lot
In fact, I think it’s the same than the genesis.
Maybe I skipped this one!
You might be right, I’ll check later!
Confirmed! This cable was still in the box as I was always using the dock. @Armen_Tangyan : You can use the cable of a Kronos Genesis, if you have one.
@Armen_Tangyan, you can buy a new one:
